Date/Time: Fri, 20 Sep 2024 03:55:56 +0000
when upgraded some time in the past i lost the numbers bars from the chart studies...
View Count: 931
[2014-09-09 08:56:36] |
ariknoi - Posts: 31 |
when i load my charts i can see on the chart the numbers bars indicator which is working properly and yet when i enter to the chart settings and wnat to set something in the numbers bars indicator i only have #.ID:1 without it's name or any option to change anything what happened? |
[2014-09-09 21:23:51] |
This is because you are using the older Numbers Bars study. You need to remove and re-add the Numbers Bars study to the chart.
[2014-09-10 04:05:06] |
k. just wondering why it's not done automaticly upon the upgrade.... :( |
[2014-09-11 02:18:36] |
Because the study inputs for the new Numbers Bars study have changed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-11 02:18:50
