Date/Time: Thu, 21 Nov 2024 12:31:04 +0000
[Programming Help] - Indicator valid for a specific day
View Count: 58
[2024-11-11 08:58:38] |
User258227 - Posts: 8 |
Hello, I have an indicator that represents a level with a horizontal line. The level (price) is defined by 2 inputs. The indicator generates various standard deviations from this. These levels are daily levels, but the indicator draws the line across the entire screen or the entire chart. In other words, over the entire set history. Is there a way to limit the lines to a specific day? And, for example, to create 5 different daily levels for each week? So add the indicator 5 times and assign whether it should apply on Monday, Tuesday or Wednesday or enter the date? Many thanks and best regards |
[2024-11-11 15:42:46] |
John - SC Support - Posts: 36174 |
We assume this is a custom study, as such you would need to modify your code to do what you want. It definitely can be done.
