Date/Time: Thu, 21 Nov 2024 12:55:47 +0000
TOPSTEP, SIERRACHART, Rithmic and CQG account
View Count: 118
[2024-11-11 08:12:24]
User513390 - Posts: 49
I just paid TOPSTEP to use with Sierrachart and i am getting the errors in the file.
I do not understand why i cannot use your system. I have log in with CQG account
Please help
Rodney
image20241111_090510.jpg / V - Attached On 2024-11-11 08:10:23 UTC - Size: 3.47 MB - 30 views
image20241111_084846.jpg / V - Attached On 2024-11-11 08:11:06 UTC - Size: 3.41 MB - 23 views
image20241111_084254.jpg / V - Attached On 2024-11-11 08:11:17 UTC - Size: 5.08 MB - 21 views
[2024-11-11 13:15:36]
Sierra_Chart Engineering - Posts: 17133
Due to restrictions on the Rithmic side you cannot connect to Rithmic more than once. Only Sierra Chart can be connected to Rithmic. No other program.
And for historical and real-time market data when using Rithmic and CQG you need to activate the CME exchanges that you require. Refer to:
[2024-11-12 10:13:18]
I have already been using CQQ and signed the all the agreements and it was working great.
Now the login works for Sierra Chart can be connected to Rithmic but still the same mistake as the uploaded picture..
When i click nothing happens and my screen is black.
image20241111_084254.jpg / V - Attached On 2024-11-12 10:10:21 UTC - Size: 5.08 MB - 12 views
[2024-11-12 16:07:32]
John - SC Support - Posts: 36174
Refer to the following regarding the "Permission Denied" error from Rithmic:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
[2024-11-13 13:23:10]
The procedure is correct. i've read before asking questions here on the forum.
Question, do i need to pay for datafeeds from sierra chart? as Rithmic does not provide for the connection to work?
[2024-11-13 15:08:35]
To solve this problem, activate the exchange or exchanges that you need here:
Yes in order to access the data reliably and without all of these permission denied related issues:
