Date/Time: Thu, 21 Nov 2024 13:03:14 +0000
Pull/Stack Sums Not Populating Correctly in Calc Values 2 Study
View Count: 66
[2024-11-11 02:14:10]
TraderBiku - Posts: 35
I am trying to get the totals from the pull/stack values from the DOM to populate in Calculated Values 2 study - I have applied this study to a 500 volume chart, and have the DOM open in a separate window with the Combined Market Depth Pull/Stack column active. I see the total values for bid and ask sides of the DOM, however, the values showing up in the Calc Values 2 study are different, and much smaller in value than what shows up on the DOM itself - for example, the DOM currently shows +217/+229, but the value that populates in the Calc Values 2 study is +5/+2. I haven't made any other modifications to the study, so I'm unclear what else I'd need to do to get the correct total from the DOM window to populate in the Calc Values study - thanks in advance for your help.
[2024-11-11 04:40:34]
Sierra_Chart Engineering - Posts: 17133
We do not see any problems with this. We see an exact match:
https://www.sierrachart.com/image.php?Image=1731299986423.png
Provide an image of the chart or Trade DOM configured identically like we have above, by following these *exact* instructions:
[2024-11-11 13:36:33]
I deleted and re-added the Calc Values 2 study and now it appears to be working as expected. Thank you!
