Date/Time: Wed, 16 Sep 2026 14:51:52 +0000
Replay Chart Market Depth/Trade DOM
View Count: 5750
[2024-11-10 23:27:31]
User781731 - Posts: 74
I’m trying to use the Replay function so that I can go back and replay the DOM. I have used the “Download Depth Data from Date-Time” option by right clicking on the chart. However when I replay the chart, the DOM does not actually replay.
I have tried using both “Standard Replay” and “Calculate Same as Real Time” in the Replay Mode setting. See screenshot for the rest of the settings.
The date I’m trying to replay from is only 10 days ago.
The standard charts replay correctly but the DOM itself isn’t. Something I noticed is when I first initialise the replay, the charts will “reload” similar to how they do whenever you open the chartbook for the first time, whereas the DOM doesn’t reload at all. See screenshot for what I mean. In the screenshot you can see there are two charts and in the middle is the DOM. Both charts reload upon clicking “play” but the DOM chart doesn’t do this. I think this has something to do with why it isn’t working.
For your information, I clicked “send for analysis” on the Message Log in case you need to review it for this.
imageScreenshot 2024-11-11 at 10.19.31 am.png / V - Attached On 2024-11-10 23:19:44 UTC - Size: 77.14 KB - 370 views
imageScreenshot 2024-11-11 at 10.21.48 am.png / V - Attached On 2024-11-10 23:22:08 UTC - Size: 283.43 KB - 383 views
[2024-11-10 23:34:29]
I also tried “Reload and Recalculate” but this didn’t fix the issue.
[2024-11-11 04:41:35]
I can also see that the depth data is downloaded because it’s saved in the MarketDepthData folder. See screenshot
imageScreenshot 2024-11-11 at 3.40.18 pm.png / V - Attached On 2024-11-11 04:41:04 UTC - Size: 234.43 KB - 319 views
[2024-11-11 04:51:47]
Ok I just worked it out. I needed to increase the “days to load” in Chart Settings > Data Limiting.
Do you know if the MBO data works in replay? i.e. being able to display single orders greater than N number of contracts.
[2024-11-11 06:00:33]
Sierra_Chart Engineering - Posts: 24877
There is no market by order data during a replay. It does not exist at all and there is no support for that.
Date Time Of Last Edit: 2024-11-11 06:01:49
[2025-02-05 00:29:41]
barucho - Posts: 17
Is there any talk on supporting MBO for market replay in the near future? I think this could be a huge benefit for implementing some automated trading strategies (backtesting). Thanks!
[2026-09-11 22:46:27]
lion323 - Posts: 79
My dom is not working on market reply even though I got market depth data downloaded for start time
[2026-09-12 12:09:52]
Refer to the instructions here:
Replaying Charts: Replaying Trade DOM Windows
[2026-09-14 07:54:30]
lion323 - Posts: 79
Got custom studies that crash
What’s the solution ?
[2026-09-14 07:59:57]
Not totally sure without in-depth debugging which we do not do but the first step is to rebuild them:
How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions
[2026-09-14 08:01:42]
lion323 - Posts: 79
It’s a DLL file
[2026-09-14 14:47:25]
Where did you get the DLL file from? Ask who provided that to you, to provide the CPP source code so it can be rebuilt.
Date Time Of Last Edit: 2026-09-14 14:47:38
