Date/Time: Thu, 21 Nov 2024 12:41:31 +0000
About the automatic disappearance of stop loss and take profit after opening a position.
View Count: 49
[2024-11-10 08:22:42] |
User886314 - Posts: 10 |
Recently, when I open a position using Sierra Chart, the original take-profit and stop-loss settings will automatically disappear when I close Sierra Chart, that is, my original take-profit and stop-loss conditions will not work when I encounter market fluctuations, which is a very fatal problem, which usually occurs when I close Sierra Chart for a few days. This problem usually occurs a few hours after closing the Sierra Chart, is this a Sierra Chart problem or a FCM problem?
[2024-11-10 17:29:53] |
Sierra_Chart Engineering - Posts: 17133 |
It sounds like, these Attached Orders are Day orders and not Good till Canceled. Refer to: Attached Orders: Time In Force Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
