Date/Time: Thu, 21 Nov 2024 12:43:23 +0000
[User Discussion] - issues updating to Version 2695 using Crossover
View Count: 107
[2024-11-09 21:44:47]
akCB - Posts: 6
Hello, I'm using Crossover for Mac to run Sierra Chart and have a message stating that I must update to Version 2695 in order to continue using the Trading Evaluator service. I have followed the steps listed here:
Software Download: Fast Update to no avail, and continue to get the message "Sierra Chart is up to date. No updates were downloaded" - and I am still on Version 2674.
The file path of my Sierra Chart install via Crossover is C:Trading\
I have downloaded the SC installer, selected the path to install the update from, and into - and the update gets about halfway through before freezing up.
Do you know if there is any reason this would not work simply due to Crossover?
imageScreen Shot 2024-11-09 at 2.29.26 PM.png / V - Attached On 2024-11-09 21:42:15 UTC - Size: 549.97 KB - 22 views
[2024-11-09 22:38:26]
Sierra_Chart Engineering - Posts: 17133
Try doing the software installation again. This issue should now be resolved.
[2024-11-09 22:44:31]
akCB - Posts: 6
Unfortunately I deleted the entire application from the bottle within Crossover, and with it, my charts, records, etc. Lesson learned - I didn't have a recent backup of everything. I will need to rebuild.
[2024-11-11 16:13:31]
Tony - Posts: 516
@akCB,
Are you using Silicon CPU or Intel CPU?
[2024-11-12 16:07:13]
akCB - Posts: 6
Intel. Curious why you ask. Thanks!
[2024-11-12 17:08:21]
Tony - Posts: 516
I would like to mention that Linux could be another option, Linux doesn't run on Silicon CPUs though.
I have a 2015 iMac running Linux Mint and a 2016 MacBook running Manjaro since mid 2019,
both have WINE installed to run some of the Windows programs, and Sierra works great
on both computers, feels like running Sierra natively.
