Date/Time: Thu, 21 Nov 2024 13:19:03 +0000
Stacking/pulling data resets and is not pre-populated issue
View Count: 56
[2024-11-09 18:49:09] |
User495282 - Posts: 6 |
I'm using the Number Bars Calculated 2 to see stacking/pulling data. I have downloaded the market depth for the symbol, but it seems that the s/p data is not pre-downloaded or something... When I press play on replay, the sub-study is empty, then it will start to populate once new bars form, I would like to have the data prepopulated. Also, anytime I change a study setting, it will reset the study to be empty again. Please help.
[2024-11-09 22:12:52] |
Sierra_Chart Engineering - Posts: 17133 |
There is no historical Market Depth Stacking and Pulling data. It can only be created in real time. What you see is completely normal. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
