Date/Time: Thu, 21 Nov 2024 13:14:55 +0000
REQ: Option to Display Fills when Flat
View Count: 75
[2024-11-08 22:20:21] |
ycomp - Posts: 316 |
I would like to request the ability to display fills when flat. I like to see fills when not in a trade, but fills kind of get in the way when trading. Just throwing it out there as an idea. thanks. |
[2024-11-09 22:46:29] |
Sierra_Chart Engineering - Posts: 17133 |
We are not understanding this. It is not making any sense to us at all. There are two different ways of looking at order fills, and both of them are fully unaffected by what the current position is. You can look at order fills in the Trade Activity Log: Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings And also on the chart: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-09 22:47:45
[2024-11-10 17:53:13] |
yeah I guess I could have explained that better. What I mean is have some other setting that hides any existing fills on the chart when a position is entered. Then, restores them when the position is flat. OR maybe easier: Just a way to toggle fills on all charts in the chartbook at once. This is probably much easier to understand. The original request came out of frustration of toggling on and off order fills on each chart one by one, but if you could do it on all charts with one keypress that would be easy. Date Time Of Last Edit: 2024-11-10 17:53:29
