Date/Time: Wed, 09 Sep 2026 07:15:58 +0000
Replay works only by 1 minute increment now
View Count: 759
[2024-11-08 19:39:27]
User94545 - Posts: 7
I have active data feed "Denali - Activated Exchange: CBOT with Market Depth for non-professional Trading accounts".
I just notice when I try to replay even when unit is set By time 1s chart is replaying only by 1 minute increment. No movement between 1 minute, 2 minute... Realtime data works fine. I was able to replay by 1s just recently. Was there some change for replay? Why am I not able to replay by 1 second increment now?
[2024-11-08 20:39:08]
John - SC Support - Posts: 47806
The replay updates the chart according to the "Chart Update Interval". Refer to the following:
Replaying Charts: Chart Update Interval During Replays
The values set in the bottom left of the Replay Control Panel are for how far to skip forward or backward, if you want to use that option. Refer to the following:
Replaying Charts: Jump
If you are only seeing updates every 1 minute for a standard replay of a single chart, then this would imply that your data is stored in 1 minute increments. Refer to the following setting:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
