Date/Time: Wed, 04 Dec 2024 08:45:51 +0000
Attached orders visual bug?
View Count: 95
[2024-11-08 15:48:24] |
User2069 - Posts: 20 |
The info on the attached orders, the pnl, ticks, points, etc, is not getting updated when i drag them. It only updates once i let go and finish modifying it. It's happening for me on both 2700 and 2703
[2024-11-08 18:13:48] |
John - SC Support - Posts: 36442 |
Make sure the option for "Trade >> Chart Trade Settings >> Working Orders >> Attached Orders P/L when Modifying" is set to "Yes". Refer to the following: Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-08 18:49:30] |
That fixed it, not sure why it got turned off but thank you!
