Date/Time: Wed, 04 Dec 2024 08:44:16 +0000
Graphics Global - Chart Trading Settings - Chart Trading Order Fills (can't seem to edit)
View Count: 132
[2024-11-08 10:24:05]
User92573 - Posts: 531
Dear Support
I'm trying to edit both the Entry/Exit Triangle size/color along with the Connecting Lines Primary and Secondary.
All the settings are there in "Graphics Global - Chart Trading Settings - Chart Trading Order Fills - etc" but other than setting the color for the fills I cannot seem to set the triangle size and nor can I see/edit the connecting lines?
Clearly, I'm missing something pretty straight forwards. Just not sure what.
Any help appreciated.
Thank you.
imageSierra Order Fills.png / V - Attached On 2024-11-08 10:23:40 UTC - Size: 31.14 KB - 26 views
[2024-11-08 15:20:51]
John - SC Support - Posts: 36442
The Fill Marker (triangle) size is controlled through the following setting:
Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
The graphics settings you have highlighted in your image will control the connecting line color and size. If that is not working, then make sure you are changing the graphics settings in the correct location (there are Chart specific graphics settings and Global graphics settings). Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
Also refer to the following setting for how the connecting lines are colored (the primary versus secondary):
Global Trade Settings Windows: Color Connecting Lines Based on Profit/Loss (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
[2024-11-08 19:33:53]
Thank you John, have a great weekend.
