Date/Time: Thu, 21 Nov 2024 13:01:36 +0000
DAX contract not updating in SC but it is realtime in IB
View Count: 115
[2024-11-08 10:23:03] |
User505707 - Posts: 17 |
Hi, I am using IB as broker and data provider, DAX contracts not updating, I get some error messages. Two days ago it was updating on chart but I had issues with getting historical data. You can see in screenshot that IB booktrader is realtime, but SC charts not updating. I have updated Sc to latest version, I have checked symbols amd downloaded it from server. Best regards, H. |
InkedChart not updating- DAX.jpg / V - Attached On 2024-11-08 10:20:25 UTC - Size: 572.75 KB - 17 views |
[2024-11-08 11:21:22] |
User584084 - Posts: 262 |
SC Version 2671 is the last release that supports getting EUREX real-time data from IB TWS. Starting with SC Version 2678 and later, all EUREX real-time data must come from the Denali Exchange EUREX Data Feed for all Trading and Data services including Interactive Brokers. You can stay on SC Version 2671 to get EUREX real-time data from IB TWS. Otherwise, if you update SC to a later release, you will need to subscribe to the Denali EUREX real-time data feed to get your DAX data. See the last line of the 2678 Release Notes: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Date Time Of Last Edit: 2024-11-08 11:25:42
[2024-11-09 23:31:48] |
Sierra_Chart Engineering - Posts: 17133 |
You need to complete the EUREX market data agreement and activate the EUREX exchange. This can be done from here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-11 08:26:54] |
Thank you. I decided that I don't need superprecise live data feed, one from IB is ok for what I am doing. So I installed SC Version 2678, b ut I have issues with charts there. I cant access all things on drop down menu afetr right click on chart.
No menu.PNG / V - Attached On 2024-11-11 08:20:06 UTC - Size: 136.16 KB - 14 views |
[2024-11-11 13:31:00] |
In the case of going back from the version that you did to an earlier version you need to reconfigure that menu. Do this with this command: Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-11 14:24:59] |
thank you, it is all I needed. thanks
