Date/Time: Thu, 21 Nov 2024 12:42:26 +0000
Using SierraChart
View Count: 89
[2024-11-08 09:49:00]
ManuMB - Posts: 2
Hello, I have 2 questions :
1) I want to be able to use Sierra Chart with prop firms who uses Rithmic. What is the minimum package I need to have ?
2) I want to be able to connect to my AMP account and have the possibility to visualize the charts in 100 and 200 ticks, which package do I need ?
3) In the past when I used the software I was often confused while the data for the charts were loading I was waiting but sometimes it didn't work can you help me understand this process.
Thanks,
Manuel
[2024-11-08 15:08:55]
John - SC Support - Posts: 36174
1. You need to be on one of the "Integrated" packages. Refer to the information here:
Description of Service Packages and Pricing: Integrated Packages
2. Same answer as #1
3. We do not understand what the issue was that you were seeing. What exactly was occurring?
[2024-11-11 20:35:33]
ManuMB - Posts: 2
Ok thank you John for the support, I have another question. If I want to connect to rithmic using prop firms do I need to have a funded account or is it okay to juste suscribe to one of the integrated packages and connect to rithmic ?
[2024-11-11 21:03:40]
If you want to get the data from Rithmic, then you do not need to connect to a funded account. Rithmic works around this somehow. But if you want to get your data from our Denali Exchange Data Feed, then you would need to connect to a funded account in order to get the non-professional data.
Just keep in mind that there is a lack of historical data with Rithmic. In general, you can get about 5 days of previous data.
