Date/Time: Thu, 21 Nov 2024 13:35:26 +0000
Prop Firms
View Count: 126
[2024-11-08 00:46:22] |
K Boogie - Posts: 1 |
Hello, I would like to subscribe to a service package but I would like to know which one is best for prop firm trading and having access to TPO and market profile.
[2024-11-08 01:28:11] |
User224654 - Posts: 18 |
Package 11
[2024-11-08 14:37:42] |
John - SC Support - Posts: 36174 |
In order to connect to a trading service and get data, you need to be on one of the "Integrated" packages. In order to have access to the TPO study, you need to be on one of the "Advanced" packages. Which means you would be on either the "Integrated Advanced" or "Integrated Advanced with MBO". The only difference is that one includes the Market by Order data. Refer to the information for the packages at the following link: Description of Service Packages and Pricing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-09 23:13:24] |
Sierra_Chart Engineering - Posts: 17133 |
Yes you will need Service Package 11. We have activated your Sierra Chart account for now. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password if necessary. 2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
