Date/Time: Wed, 04 Dec 2024 08:44:10 +0000
ACSIL trading system limitations
View Count: 129
[2024-11-07 22:07:05] |
User745789 - Posts: 327 |
Hello, before I hire a developer, is this basic concept possible within one trading system ACSIL script. - entry on stop (easy) - add to position if goes into profit, adjust qty on stop loss when position added, move stop loss to entry of first position - work profit targets for the above positions - stop and reverse position if goes into loss - add to this new position if it goes into profit, adjust stop loss qty accordingly - worked profit targets for the new reversed position. Working long and short side at the same time and cancelling the side that doesn't get filled. Date Time Of Last Edit: 2024-11-08 01:55:53
[2024-11-08 14:35:13] |
John - SC Support - Posts: 36442 |
Yes, this is all possible. You just need to know the exact logic you want to use for each situation so it can be coded.
[2024-11-08 18:44:21] |
Sierra_Chart Engineering - Posts: 17353 |
Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
