Date/Time: Wed, 27 Nov 2024 18:34:03 +0000
Point of Control Name Label Issue
View Count: 1210
[2014-09-08 20:11:21]
ged - Posts: 233
I have several VWAP and VBP studies on my chart.
In regard to the VWAP studies, I have the various VWAP lines and the standard deviations of the VWAP(s) labeled by name at the right edge of my chart. No problems.
However, in regard to the VBP studies, I cannot get name labels to appear for the several Points of Control. The Points of Control are visible, but not their name labels. The color(s) used for the Point(s) of Control are the same colors I have assigned for the various name labels, so the problem is not that the colors are not visible/showing up on the chart.
I have followed the instructions in the documentation for applying name labels to Points of Control (in Volume By Price studies), i.e. checking "Show" Name Label; "Right Edge" Horizontal Align; "Centered" Vertical Align; a short name for each POC has been typed into the "Short Name" box; and under "Settings and Inputs" the "Extend Point of Control" field is set to "End of Window".
Again, all of the Points of Control are visible, but none of their labels are visible. All of the VWAP and VWAP standard deviation name labels are visible.
Sorry to trouble you with this, but I can't find the problem. Thanks for your help.
[2014-09-08 22:22:53]
ged - Posts: 233
In the event it should matter, I'm running version 1182.
ged
[2014-09-10 13:16:11]
ged - Posts: 233
Status of this request?
[2014-09-10 16:24:26]
We have not had time to review this yet.
What we will need though is a Chartbook containing one chart which demonstrates the problem. Provide it by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2014-09-10 18:04:53]
ged - Posts: 233
Here is the attached 1 chart chartbook. Thanks much.
Private File
[2014-09-11 09:25:17]
What we see is we have to add the capability to support the Name labels for the value area and point of control lines for the Volume by Price study.
[2014-09-11 14:17:51]
ged - Posts: 233
"...we have to add the capability to support the Name labels for the value area and point of control lines for the Volume by Price study."
Any estimate as to when those additions will be made?
[2014-09-11 16:26:59]
We will try to have this ready next week.
[2014-09-30 18:18:51]
ged - Posts: 233
I'm running version 1187. Has the VbP name label correction been made in one of the subsequent releases? Thanks much.
[2014-09-30 18:54:18]
Yes.
