Date/Time: Wed, 27 Nov 2024 12:27:41 +0000
Spreadsheet Trading Help
View Count: 933
[2014-09-08 19:21:11] |
User20702 - Posts: 13 |
Hello Support I am using the Spreadsheet System for Trading. I would like to pass instructions from the spreadsheet Buy Entry, Buy Exit (Sell), Sell Entry, Sell Exit (Buy) direct to the dom (SIM) for now live later. Do you have code "examples" just so I can learn quicker. I want to send Limit orders with entry price, stops and so on, but I would be happy with any code examples you could send me. Thanks Dave |
[2014-09-09 06:05:04] |
Have you referred to the documentation here for the Spreadsheet System for Trading study: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php Limit orders are supported. And you can also use Attached Orders as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
