Date/Time: Wed, 27 Nov 2024 12:25:10 +0000
help
View Count: 1361
[2014-09-08 19:15:20]
julian pineda - Posts: 60
where in SC im able to do a mathematical logic?
i need to do this: Study 1 and study 2
if study 2 is > 0 then: Study 1 + study 2
or
if study 2 is < 0 then: Study 1 - study 2
[2014-09-09 05:36:17]
The easiest way to do something like this is to use the Spreadsheet Study:
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html
[2014-09-09 14:34:49]
it shows invalid formula. what i am doing wrong?
http://screencast.com/t/H7j8VsNmwA5P
[2014-09-09 14:56:47]
Sawtooth - Posts: 4120
Two things to consider:
1) Use a semicolon ; instead of a comma , for a separator.
2) Use a Formula Column (K-Z) for user calculations.
[2014-09-09 15:43:22]
at the moment I put a semicolon de platform returns: Invalid formula. it only let me work with a comma but at the end it returns invalid formula as well.
[2014-09-09 15:56:46]
in the other hand, everything i tried to calculated in cells K-Z cleared it self
[2014-09-09 17:13:55]
The syntax of your formula looks correct.
You must enter the formula in row 3 of any column K-Z.
In the spreadsheet study settings, set the The Formula Source Sheet Number to 1 to match Sheet1, and set the Chart Data Output Sheet Number to 0.
