Date/Time: Thu, 21 Nov 2024 17:02:32 +0000
Footprint- Number bars Percent Compare with 0
View Count: 60
[2024-11-06 19:48:36]
vddfollow - Posts: 18
Dear forum,
On the number bars study,
I use percent compare to spot imbalances between Bid and ask volumes.
I would like the percent been triggered also when value are 0 (see screenshot attached)
Do I have any inputs settings I missed ?
Regards
Date Time Of Last Edit: 2024-11-06 19:49:12
imageimage_2024-11-06_204620858.png / V - Attached On 2024-11-06 19:46:21 UTC - Size: 19.6 KB - 20 views
[2024-11-06 20:07:33]
John - SC Support - Posts: 36189
There are two Inputs that handle this situation. Refer to the following and the one below it:
Numbers Bars: Enable Diagonal Bid/Ask Compare with No Data at High/Low
