Date/Time: Thu, 21 Nov 2024 16:46:29 +0000
MA re-painting
View Count: 70
[2024-11-06 17:29:41]
cnev - Posts: 17
I totally understand if its not possible but I wanted to ask anyway.
I am overlaying an EMA from a 5min to a 1min for example.
I set a Color bar signal to trigger on the 1min 2t above the MA on close and it fires before the 5min bar closed.
By the time the 5min bar closes the 5min MA has shifted invalidating the signal.
I understand this is going to happen but what I want to know is...
Is there a way to latch the 1min signal when it occurs and even when the 5min changes, the signal remains triggered?
[2024-11-06 19:12:20]
John - SC Support - Posts: 36186
What we would need to understand is how you would eventually set the condition back to False?
[2024-11-06 20:32:27]
cnev - Posts: 17
Thanks John for the quick reply. I would prefer to leave it as true if it occurs I dont need or want the reset back to false.
[2024-11-06 21:20:46]
To create a persistent state based on an event, use a formula that looks like the following in a Spreadsheet Formula study:
=IF(C > ID1.SG1 + 2 * TICKSIZE, 1, ID2.SG1[-1])
Where C is the Close of a bar, ID1 is the ID of the Moving Average study and the SG1 following it is the actual subgraph, ID2 is the Spreadsheet Formula study and the SG1 following it is its subgraph. the nomenclature of [-1] is to look back at the value one bar prior.
