Date/Time: Thu, 21 Nov 2024 16:40:17 +0000
control bar hotkey
View Count: 54
[2024-11-06 15:23:55]
jakeybleez - Posts: 56
i could not find anything anywhere nor on asking AI
is there a way to have a hotkey for a custom time period that i have as a button on my control bar?? i can go to hotkey settings and make hotkeys for time periods, but only 1,5,10 etc. if i make a hotkey for "custom" it pulls up the settings
i have 30s,1m and 3m buttons on my charts control bar and am trying to make a hotkey for each of them
thanks so much
imagebuttonhotkey.png / V - Attached On 2024-11-06 15:23:49 UTC - Size: 5.38 KB - 13 views
[2024-11-06 16:57:16]
John - SC Support - Posts: 36186
There are 50 Custom Bar Period Control Bar buttons that you can setup to be any time frame you want. Select one of these buttons to add it to a control bar and then highlight it on the right and select the "Set Period" button to select the particular Bar Period you want. Refer to the following:
Control Bar: Custom Buttons for Intraday Chart Bar Period
