Date/Time: Thu, 21 Nov 2024 16:10:06 +0000
NASDAQ stocks
View Count: 60
[2024-11-06 13:48:01] |
User869226 - Posts: 2 |
Hi I just actived my account with Denali and Nasdaq TotalView. Interested in looking at NASDAQ stocks When I go to Find Symbol, I can find ~400 NASDAQ tickers, but most ticker on the NASDAQ are not there. In order to access the NASDAQ tickers, In my account do I need to activate/purchase additional options? Thank you |
[2024-11-06 16:50:07] |
John - SC Support - Posts: 36185 |
There are too many stocks for us to be able to list them all in the "Find Symbol" settings window. The ones you see are some of the most popular. To open a chart for an unlisted stock, you need to type in the required name in the Selected Symbol field, which is the standard ticker with a -NQTV suffix such as TSLA-NQTV. And then select the button to open an Intraday chart or an Historical chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
