Date/Time: Fri, 20 Sep 2024 02:48:34 +0000
Flex Renko bars
View Count: 1065
[2014-09-08 16:17:01] |
jaban - Posts: 66 |
Hi I like this Flex Renko bars a lot They look pretty simular to the New Woodies bars Is this accidental or do they have the same software base |
[2014-09-08 18:10:46] |
They definitely do not have the same software base.
