Date/Time: Tue, 18 Feb 2025 22:23:51 +0000
Best way to duplicate a trading spreadsheet
View Count: 130
[2024-11-06 08:22:42] |
User745789 - Posts: 365 |
Using Windows Explorer I copy/paste a spreadsheet in an attempt to get an exact duplicate. But when I apply it to another chart, numerous spreadsheet settings have reverted to default, and the spreadsheet does not work as as expected What is the correct/best way to duplicate a spreadsheet exactly? |
[2024-11-06 16:08:51] |
John - SC Support - Posts: 38029 |
Is this a standard spreadsheet, or a spreadsheet that is generated by using one of the Spreadsheet Studies?
[2024-11-06 18:14:41] |
From a study, spreadsheet for trading. I actually think the only setting that reverted was "Allow entries with working orders" |
[2024-11-06 19:16:41] |
If what you are wanting is to have the Inputs set the same, then the best way to do this is to either set a custom set of defaults for that study, or to use a Study Collection. Refer to the following: Chart Studies: Using Custom Default Study Settings Study Collections If you are wanting to duplicate a sheet within the Spreadsheet, then this becomes more difficult. Let us know if this is something that you are wanting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
