Date/Time: Wed, 27 Nov 2024 13:06:48 +0000
Switch my sierra account to CQG data
View Count: 1945
[2014-09-08 16:14:57] |
User20409 - Posts: 1 |
I have an account at AMP Trading. I have two valid logins, and pay for the second login so I can separately monitor my account status while trading. I use NinjaTrader, and though I love it operationally, occasionally it flips out and that is when I use the second login to see what is happening with my trade. I would like to switch my Sierra subscription over to CQG as a data source so I can connect to AMP through Sierra, using my second login. Is this possible. I had a demo login with AMP but it used Rhythmic data, but my second login uses CQG data. Will this work? If so, how do I get Sierra converted over to CQG? Thanks |
[2014-09-08 16:48:31] |
In the copy of Sierra Chart which is using your Sierra Chart Account Name that you directly pay for, simply follow the CQG set up instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
