Date/Time: Thu, 21 Nov 2024 16:20:01 +0000
Connecting to Sierra
View Count: 71
[2024-11-04 20:28:52] |
User780992 - Posts: 2 |
I am having trouble with the charts connecting and disconnecting. It’s also giving a message that says downloading continuous contract. Please advise
[2024-11-05 16:16:50] |
John - SC Support - Posts: 36186 |
Refer to the following: Rithmic Trading Platform Service: Frequent Reconnections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-06 00:16:26] |
Would the Teton futures order routing replace the rithmic trader pro or would I use it in addition to it?
[2024-11-06 15:31:45] |
Teton is an Order Routing Service, similar to Rithmic. But, Teton only has support for the CME Group. If you are using a broker that supports both Rithmic and Teton and you are only trading the CME Group, then you could change your order routing service to use our Teton Order Routing. But, if you are connecting to a Prop Firm, or you are using Rithmic to trade other exchanges, then you will not be able to change to Teton. Refer to the information for the Teton Order Routing service at the following link, noting the list of brokers in Step #2 of the Setup Instructions on this page: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
