Date/Time: Wed, 16 Sep 2026 23:05:00 +0000
Multiple Number Bars updating
View Count: 502
[2024-11-04 16:16:57]
prince72 - Posts: 1
Dears, I have configured a NumberBar chart. I expect only the most recent bar to update the prices. Instead both the last and the second last bars are updating prices. In addition the last bar is not displaying volume bars. Can you help with this issue? I have tried everything and I could not find an answer on the board.
Many thanks
R.
imageScreenshot from 2024-11-04 17-10-50.png / V - Attached On 2024-11-04 16:16:46 UTC - Size: 39.78 KB - 144 views
[2024-11-04 16:23:27]
User431178 - Posts: 906
The last column in the chart is the pullback column: Numbers Bars: Pullback Column
If you don't want to see that, turn it off.
If you do want to see that, and have volume bars displayed, the pullback column has it's own setting for that.
[2024-11-04 18:28:25]
Sierra_Chart Engineering - Posts: 24877
That might be the pullback column but we cannot tell from that chart by looking at it. Since it has no timescale at the bottom.
