Date/Time: Tue, 18 Feb 2025 22:44:10 +0000
Spreadsheet only has one sheet?
View Count: 108
[2024-11-04 15:46:19] |
User321897 - Posts: 3 |
Hi, I somehow messed up my spreadsheets I think. When I add "spreadsheet system for trading" study, I only get one sheet now "Sheet1" where I used to also get "Sheet9" where I could make changes. Is there a way to fix this? |
[2024-11-05 17:30:34] |
John - SC Support - Posts: 38029 |
By default, the Sheet number is going to be the number of the chart. So if you add the "Spreadsheet System for Trading" to chart #5, the sheet number for that chart is going to be "Sheet5". The controls to change this start at the following link and are the following 2 Inputs: Spreadsheet Study Inputs: Chart Data Output Specification Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
