Date/Time: Thu, 26 Dec 2024 21:20:23 +0000
No Data
View Count: 105
[2024-11-04 14:40:06]
cmack1011 - Posts: 54
It appears that I am no longer receiving data. Please advise.
Thx
[2024-11-04 14:57:18]
Sierra_Chart Engineering - Posts: 17672
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-11-04 15:52:22]
When I attempt to clear the message log, after selecting "edit - clear log - clear log lines - yes" the system only clears one line of messages - there appears to be ? hundreds of lines. Please advise
[2024-11-04 17:02:02]
There cannot be anything wrong with the clear Message Log functionality but once it is cleared, there will be about 20 or so lines added, which are the standard information lines.
That is normal.
