Date/Time: Thu, 26 Dec 2024 21:12:37 +0000
Does a 4k 27 inch monitor fit as many bars into a Sierra window as a 4k 32 inch monitor?
View Count: 122
[2024-11-04 12:10:45]
A77 - Posts: 18
You'd think the 32 inch monitor can fit more due to more screen real estate but the number of pixels is the same, so in theory if each bar is a pixel, one would get no benefit of upgrading from a 27 inch 4k to a 32 inch 4k.
Am I correct?
[2024-11-04 14:20:35]
User690628 - Posts: 11
It's the resolution, not size that makes the difference here. In the case of the 32" 4K, everything will just be larger than on the 27", but otherwise it will appear the same.
[2024-11-04 18:14:34]
Sierra_Chart Engineering - Posts: 17672
Yes this is a correct understanding at post #1.
