Date/Time: Thu, 26 Dec 2024 20:47:09 +0000
Replay Latency
View Count: 112
[2024-11-04 03:33:53] |
Gradient - Posts: 89 |
Hi, When conducting replays using ACSIL, I've notice a lag in fills as well as OCO order processing. For example, DPL is 0 and then at the end of day, it updates and orders appear but were executed multiple bars earlier prior to DPL and fills being updated. All orders are OCO, but some don't have an attached target. Can someone advise why this is occurring? |
[2024-11-04 20:19:32] |
Sierra_Chart Engineering - Posts: 17672 |
Do you mean you are controlling the replay through ACSIL?: When conducting replays using ACSIL,
What is the speed of the replay? Try slowing it down. There may be slow user interface updating, but still all of the Trading calculations in the background are going to be done immediately as needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-04 20:26:35] |
I've tested at 480 and 960 both at 30sec and 60sec processing.
[2024-11-04 20:55:24] |
The user interface may not be visually showing all of the updates and that is normal. We recommend using a slower speed.
