Date/Time: Mon, 28 Sep 2026 03:22:58 +0000
Accumalative Delta Different on FXCM & FXCM live
View Count: 2316
[2014-09-08 14:12:40]
User15378 - Posts: 45
Hi there
I have a trial version using the FXCM data, is the demo data and live data different, because my friend is using the live data and his Accumalative delta looks very differnt to mine & i am on demo. Our setting are all the same?
please clarify
Thank you
Nic Labuschagne
[2014-09-08 16:16:01]
There could be some differences.
What is the specific name of the study you are using?
[2014-09-08 18:54:47]
i am using cumulative delta bars- up/down tick volume. i am opening up a account with you guys at the end of the month and i hope the live feed is going to be correct because there was quite a difference.
Anything else you can recommend? or just wait till i get the live feed to see.
i am also doing it on tick by tick data so its the most accurate
thanks
[2014-09-11 04:41:36]
As long as you have set Sierra Chart for a tick by tick data configuration there really is not anything more we can recommend:
