Date/Time: Sun, 20 Sep 2026 04:43:10 +0000
[Programming Help] - Programming Help - SpreadSheets Loop Count
View Count: 563
| [2024-11-03 22:37:30] |
| Le Dharma - Posts: 86 |
Hey Sierra. I am trying to program an equation In Spreadsheets. I would like to create a counter, which counts only the last 50 bars (rows). The counter could start at 50 and count downwards, in P3, or It could start at 1 and count to 50, on row P53. Can anyone help me figure out how to create a counter in spreadsheets? Thanks, -Ben Date Time Of Last Edit: 2024-11-03 23:03:46
| [2024-11-03 22:50:03] |
| User224654 - Posts: 23 |
Try this in cell P3: =MOD(ROW() - 3, 50) + 1 Explanation: ROW() returns the current row number. ROW() - 3 adjusts the row number, as Sierra Chart data typically starts from row 3. MOD(..., 50) calculates the remainder of division by 50, resulting in values between 0 and 49. Adding 1 shifts the range to 1 through 50. This formula will count from 1 to 50 and automatically reset after each 50-bar cycle. Note: In Sierra Chart, formulas are usually entered in row 3 and applied automatically to rows below. Make sure the formula is in the correct starting row for the desired effect. |
| [2024-11-03 23:05:11] |
I should not have said, I dont mind using a counter which repeats. I do need a counter that stops after the first 50 bars. Does anyone know how to write this? |
