Date/Time: Thu, 21 Nov 2024 17:52:18 +0000
Seperate Instance w/ Diff Data Feed Login?
View Count: 63
[2024-11-03 21:40:11] |
HeyUgly - Posts: 247 |
Is this possible? Im running a rithmic instance of my Sierra, charts , no issue. Im trying to run a seperate instance of Sierra Charts, but with a seperate Rithmic ID Login I try to change the information on the new instance, but Box that usually comes up to fill out the data trade service settings.... is not there in the new instance. I am guessing this is not possible?? |
[2024-11-03 21:52:38] |
for refrence... I cannot choose a different login for the new instance. pic attached |
Capture.PNG / V - Attached On 2024-11-03 21:52:31 UTC - Size: 27.89 KB - 17 views |
[2024-11-03 23:15:59] |
Sierra_Chart Engineering - Posts: 17136 |
Yes this is true. It is not possible to change the Service in the case of a sub instance started with File >> New Instance. You need to install a completely separate installation: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-03 23:16:15
