Date/Time: Thu, 21 Nov 2024 16:49:42 +0000
Drawing not copying to other charts on same chartbook
View Count: 54
[2024-11-03 18:44:51] |
Blackcode - Posts: 1 |
Hello, I have a problem with copying, I have these settings and nothing is copied. Sierra version 2700 I'm still looking for a solution but I don't know what the problem |
Attachment Deleted. |
[2024-11-05 16:12:13] |
Sierra_Chart Engineering - Posts: 17136 |
Refer to: Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
