Date/Time: Thu, 26 Dec 2024 20:49:23 +0000
Reset Windows
View Count: 135
[2024-11-03 08:20:59]
nicktrader - Posts: 721
I switched to Win11 nearly 2 weeks ago and I am using Rel: 2700. I use 3 monitors. I also use a laptop and copy my chartbook to it often.
As soon as I use the crosshairs, the "value window" pops up. The values window is set to "Save... position for each...".
By switching to Win11, I have now discovered on the laptop that I have to click on each chart individually with "Reset Windows" in order to see the "Value Window".
Under Win10 I only had to click once for all charts (as far as I can remember).
Is there a "shortcut" or other solution so that I only have to click once?
Many thanks
[2024-11-05 10:35:18]
Unfortunately no answer yet. But okay. I'm starting to understand when and when not...
Anyway, I think I've found a good solution for myself.
On the laptop the platform is set to "No" for "Save Tool Values Window Position..." and on the desk PC it is set to "Yes".
Have a nice day.
[2024-11-05 15:17:22]
John - SC Support - Posts: 36871
What you state makes sense. If the Tool Values Window is not shared for all charts, then you would need to reset the child windows in order to get that window reset for each chart.
