Date/Time: Sun, 24 Nov 2024 02:19:07 +0000
v2700
View Count: 154
[2024-11-03 07:54:13] |
User585104 - Posts: 142 |
Hi, When you place an order on the chart the lollies that show your entry, target and stop amounts in points used to change as you moved them. Now the points remains static until you let go. I assume this is an error as it very annoying Thanks |
[2024-11-03 20:26:38] |
Sierra_Chart Engineering - Posts: 17154 |
We are not sure what you are referring to. Are you referring to the display on the order line of the profit/loss for Target and Stop orders when modifying them?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-03 20:26:45
[2024-11-03 20:28:06] |
Hi, Yes that's right Thanks |
[2024-11-04 00:21:06] |
Set Global Settings >> Chart Trade Settings >> Working Orders >> Attached Orders Profit/Loss when Modifying to Yes.
[2024-11-04 01:48:18] |
Hi there, Yes that a fixes the problem. Are there any other settings that may have changed during this version upgrade that you are aware of? Thank you |
[2024-11-04 04:16:44] |
That setting would not have changed. The issue was it was never implemented. We only just implemented it recently.
