Date/Time: Sun, 24 Nov 2024 02:15:50 +0000
Chart DOM Settings not reflecting on my DOM
View Count: 95
[2024-11-02 22:17:54] |
salecer - Posts: 3 |
Hello, I'm looking to clear my recent bid/ask volume every 2500ms or at every new position and I checked "Reset Recent Bid/Ask Volume on Bid/Ask Change" to yes, "Clear Current Bid/Ask Volume on New Position" to yes and set 2500ms on "Recent Bid Ask Volume Timeout in Milliseconds" but I see no change and no clear or reset on my columns Recent Bid Ask Volume. Settings: https://www.sierrachart.com/image.php?Image=1730585633654.png DOM in replay mode: https://www.sierrachart.com/image.php?Image=1730585715447.png Best regards. |
[2024-11-03 13:34:02] |
I would like to do something like that. Clearing the DOM every 2500ms I attach a little video |
Attachment Deleted. clearbidaskmp4.mp4 - Attached On 2024-11-03 13:33:29 UTC - Size: 2.61 MB - 20 views |
[2024-11-03 20:34:52] |
Sierra_Chart Engineering - Posts: 17154 |
There is not support for what you want to do. There is no option to do an automatic reset of that data every n milliseconds. There is a misunderstanding about this setting: Global Trade Settings Windows: Recent Bid Ask Volume Timeout in Milliseconds (Global Settings >> Chart DOM Settings >> Other >> Other Settings) You can develop your own custom study to do this. Using ACSIL: Advanced Custom Study Interface and Language (ACSIL) There is a function in ACSIL to clear the recent bid/ask volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-03 20:37:01
