Date/Time: Thu, 21 Nov 2024 17:13:40 +0000
CVD Indicator Discrepancy Between Sierra Chart and TradingView for VX Futures
View Count: 91
[2024-11-02 17:27:43] |
User708340 - Posts: 6 |
Hi SC Support, I've noticed a discrepancy in the CVD indicator between Sierra Chart and TradingView for VX futures. While the CVD indicator on both platforms looks similar for ES futures, there's a notable difference for VX. I'm curious to know why this difference exists. Is there a mis-calculation or data source difference between the two platforms that could be causing this? SC support, please share your insights. Thanks, |
SierraChart VX futures and CVD.JPG / V - Attached On 2024-11-02 17:26:25 UTC - Size: 227.03 KB - 35 views Tradingview VX futures and CVD.JPG / V - Attached On 2024-11-02 17:26:30 UTC - Size: 224.46 KB - 37 views |
[2024-11-02 21:18:15] |
Sierra_Chart Engineering - Posts: 17136 |
This is because Sierra Chart provides, 100% accurate data, regarding Bid volume and Ask volume, for CBOE volatility index futures since the data feed from the CFE is an order by order data feed. What you see is 100% correct and precise in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-02 21:18:28
