Date/Time: Sun, 24 Nov 2024 03:21:51 +0000
Main Panel Graphics Problem
View Count: 76
[2024-11-02 12:39:56]
sadramistes - Posts: 11
just yesterday an error appeared when using SC regarding graphics that i never had before. As you see on the screenshots, when i move any window attached to the main panel, it creates a double or triple iamge of it, sometimes corrupted accompanied with a lag on the main panel windows. This is happening only with the windows attached to the main panel, and not the loose windows. As you understand this creates frustration whenever i'm trying to move a window within a panel.
Before i write this thread i made sure to have updated to the latest version and tried to close and reopen the SC many times with the same result. Note that this happening only with SC and not with anything else on my computer, so it is not an OS problem, or computer graphics problem. Everything else is running smooth.
I'd appreciate if there is a way to fix it.
Thank you
Date Time Of Last Edit: 2024-11-02 12:41:25
imageScreen Shot 02-11-2024 at 12.23.png / V - Attached On 2024-11-02 12:41:04 UTC - Size: 177.75 KB - 31 views
imageScreen Shot 02-11-2024 at 12.25.png / V - Attached On 2024-11-02 12:41:12 UTC - Size: 156.14 KB - 28 views
