Date/Time: Thu, 21 Nov 2024 18:04:21 +0000
Easy question - SC on Win 10 being upgraded to Win 11
View Count: 113
[2024-11-02 12:37:14]
dkayUK - Posts: 2
hi
Does SC survive the upgrade? Anything I should know.
I will back up the SC folder before I start.
thanks
David
[2024-11-02 17:20:11]
ForgivingComputers.com - Posts: 959
You should have no problem with the upgrade. Sierra Chart is not "installed" into Windows the way most other programs are. It is a standalone application that does not rely on Windows Registry settings or other dependencies.
[2024-11-02 23:35:45]
Sierra_Chart Engineering - Posts: 17136
Yes no problem updating your operating system with Sierra Chart fully unaffected. It is independent and portable:
Software Download: Portable Design
