Date/Time: Wed, 18 Dec 2024 02:02:12 +0000
Can there be a line across chart while I put mouse on chart dom?
View Count: 121
[2024-11-02 07:47:40]
gaoxxxx - Posts: 3
I want it to show a line across chart wihle I put mouse on the chart dom for me to know the exact place I am about to make order. Is that possible like this?
image屏幕截图 2024-11-02 153600.png / V - Attached On 2024-11-02 07:46:42 UTC - Size: 59.07 KB - 26 views
[2024-11-02 21:16:19]
Sierra_Chart Engineering - Posts: 17555
Yes this is supported with the Chart Values tool:
Chart Drawing Tools: Chart Values/Crosshair
You simply enable the Tools >> Chart Values tool, and then you will have a line across the chart, as you enter orders through the Chart DOM.
There is an option to keep it always active with other tools as well:
Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values)
Date Time Of Last Edit: 2024-11-02 21:16:49
