Date/Time: Thu, 21 Nov 2024 21:27:47 +0000
Techniqual
View Count: 86
[2024-11-01 11:43:45]
User548772 - Posts: 9
Hello
My status says I am not connected. I don't know why, my Internet connection is not the Problem.
My Quoatboard is also blank.
In the attachment with the chart you can see that I am 1 day behind. So it's not 01.11 on the chart, but 31.10. Although I should have real time data.
imagesierra.PNG / V - Attached On 2024-11-01 11:30:44 UTC - Size: 45.16 KB - 21 views
imagesierra2.PNG / V - Attached On 2024-11-01 11:41:03 UTC - Size: 76.74 KB - 24 views
[2024-11-01 15:46:51]
Sierra_Chart Engineering - Posts: 17138
Looks like you have a connection problem to CQG.
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
