Date/Time: Sun, 24 Nov 2024 15:19:09 +0000
Erase All Non-Text Drawings Button Bug
View Count: 62
[2024-11-01 11:00:01] |
Deenius - Posts: 19 |
I want to report a bug. I wanted to add the button "Erase All Non-Text Drawings" to my control bar, but I couldn't find it. This option is not there. Instead, there is an option to add an "Erase Lines" button which will delete all non-text drawing objects. I think this is a bug in the naming of the function. |
[2024-11-01 14:03:50] |
Sierra_Chart Engineering - Posts: 17156 |
This is just a simple naming issue. We will correct that name. The name currently is Erase All Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
