Date/Time: Wed, 04 Dec 2024 09:03:20 +0000
NYMEX TTF and TTG Futures
View Count: 170
[2024-11-01 08:18:54]
eaglefutures - Posts: 48
Hello I have the full CME Group and cannot get these symbols
TTF and TTG which is natural gas Dutch futures.
Is there a way for me to load these symbols and clone for example NG and make a copy of it and then it will pull through.
Or does each symbol have to be added by Sierra Charts on a per request basis.
thank you
[2024-11-01 15:42:22]
Sierra_Chart Engineering - Posts: 17353
Regarding the symbols, we need to know what Global Settings >> Data/Trade Service Settings >> Current Selected Service set to?
We need to make certain the symbols are listed for that particular service.
Date Time Of Last Edit: 2024-11-01 15:42:36
[2024-11-01 16:38:16]
Teton CME Order Routing is what I am connected to
[2024-11-02 15:45:03]
Okay we will set up these symbols for Teton order routing.
[2024-11-02 17:11:25]
You guys are rockstars. Can you advise if I want to analyse uncommon instruments and spreads will each symbol have to be approved by you or is there a way just to copy a similar instrument and change something under Global Symbol Settings in a cloned symbol
[2024-11-15 20:21:26]
These TTF and TTG symbols will be available over the weekend. They will be available for Teton order routing and SC Data-All Services .
We do have to manually add any new symbols and it is easiest for us to add them to the SC Data-All Services service.
You can always set up a separate installation of Sierra Chart to use that service:
Using Multiple Data and Trading Services at the Same Time
[2024-11-16 23:13:41]
