Date/Time: Thu, 21 Nov 2024 22:11:54 +0000
Trading: Position Quantity
View Count: 71
[2024-10-31 22:26:48] |
TraderGD - Posts: 4 |
Hello, The SC indicator "Trading: Position Quantity" is showing a value of -1 when I am confirmed flat. When I am in a long position is subtracts 1 from the total quantity, and when short it shows 1 more than I have on. The problem just started a few days ago. It is only doing it on one of two computers, the other machine works fine. I have tried removing the indicator and putting it back on, I have tried resetting it to default values. I am running SC v2695. |
[2024-11-01 08:29:08] |
Sierra_Chart Engineering - Posts: 17138 |
This is because that study is using the internal trades list of the chart. Not the true position. Therefore, you need to refer to the information here and ensure it is tracking the necessary fills from the correct Start Date-Time and there are no missing fills: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-01 08:30:05
