Date/Time: Thu, 21 Nov 2024 22:18:10 +0000
Scroll All Charts To End Function Does Not Work
View Count: 91
[2024-10-31 20:17:21] |
Deenius - Posts: 19 |
Hello, I have one chartbook and 20 charts in it. When I use the Scroll All Charts To End function none of the charts scroll to the end of the window. I use both the CTRl+END keyboard shortcut and the added button on the control bar. Unfortunately none of this works. However, if I select only one chart and use the END key, the chart scrolls to the end. Please provide a solution. Thank you. |
USDX-ES-NQ-YM-MTF.Cht - Attached On 2024-10-31 20:14:37 UTC - Size: 93.46 KB - 30 views Private File Attachment Deleted. |
[2024-10-31 20:50:48] |
John - SC Support - Posts: 36199 |
We are not able to reproduce this, even with your chart and configuration file. If you are not on the current release, then please update to the current version (v 2695) by following these instructions: Software Download: Fast Update Let us know if you continue to have an issue with the latest release. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-01 07:27:54] |
I'm using the current version, but unfortunately, it doesn't work. Any idea what could be causing this problem? I really need this functionality. |
[2024-11-01 15:13:39] |
Sierra_Chart Engineering - Posts: 17138 |
Update Sierra Chart to the latest version which is 2700 and try again. We do not see this problem. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-01 15:50:44] |
For some reason, it started working. However, I ran into another problem. When I use the "Go To End Of Chart" option, the chart scrolls to the end and leaves the offset. However, when I use "Scroll All Charts To End", the chart scrolls to the edge of the window with no offset. I have set "Default Right Side Fill Space" to 4. |
[2024-11-01 17:03:38] |
This will have to be looked into later by us.
