Date/Time: Thu, 21 Nov 2024 17:56:14 +0000
tpo letter colour
View Count: 104
[2024-10-31 18:30:16] |
User801402 - Posts: 21 |
Hi sierra team, i would like to have the tpo´s D,E,F,G of my rth profile coloured in red. Therefore i use "use letter/block colour 1-18". Unfortunately this setting also affects my eth profile which i would like to have only in grey colour. How can i solve this? Thank you !!! Jens |
tpo question.PNG / V - Attached On 2024-10-31 18:27:48 UTC - Size: 25.33 KB - 20 views |
[2024-10-31 18:42:27] |
John - SC Support - Posts: 36193 |
There is no support for exactly what you are wanting to do. Both sessions will use those colors for those TPOs if you are using the Letter/Block Color 1-18. There is an option to color the Regular session from the Evening Session, but this is for all blocks to be a single color. Refer to the following Input for the available options: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-01 15:56:13] |
Is there a way to colour the background of these tpo`s without colouring the whole chart from top to bottom (like the study "time range highloght does")?
Date Time Of Last Edit: 2024-11-01 15:56:54
[2024-11-03 22:56:30] |
Sierra_Chart Engineering - Posts: 17136 |
We can add support for this: Unfortunately this setting also affects my eth profile which i would like to have only in grey colour. We could designate Color 18, for all evening session, blocks/letters. With that work? This will be a new setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
