Date/Time: Sun, 05 Jan 2025 05:03:50 +0000
Rithmic data feed
View Count: 182
[2024-10-30 18:55:55] |
User596629 - Posts: 11 |
I am unable to use sierra chart to trade with any prop firm with this rithmic issue. I just had to cancel 5 accounts with takeprofittrader because I cant use sierra chart and none of the firms will assign my accounts thru teton. Can you help me with this issue, I love sierra chart but I can't prop firm trade with it, is there some other way? thank you!
[2024-10-30 19:00:29] |
John - SC Support - Posts: 36980 |
Unfortunately, most (if not all) of the Prop Firms use Rithmic. And there are simply issues with Rithmic and the interface that exists, which was written by Rithmic. This is NOT something we can resolve. The only option is to not use Sierra Chart with Prop firms. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-30 20:13:38] |
cesium - Posts: 100 |
Describe the issue you’re having, you didnt describe anything. Rithmic is plug and play in Sierra. Username and password. I don’t understand.
